2 hours ago
My account shows calls that I have not made!
How to stop those activities so I don't get billed for calls I don't recognized?
an hour ago
post us the screenshot, maybe we can tell what numbers are those
2 hours ago
It you are sure that your phone is hacked, it’s better to rest the phone to factory and remove all appliances.
2 hours ago
They are just regular looking numbers. None of those 4001s the community is reffering to.
2 hours ago
First and foremost @kaostream1 , Public Mobile is a PREPAID service. Meaning you pay for services in advance. There are no "Surprise" fees. You only get what you pay for. I am pretty sure the number that's coming up is probably for Public Mobile voicemail. Here's the link to confirm.
2 hours ago
Are these numbers all different or all all the same ending with 4001/2?
If later then it is your voicemail where unanswered calls end up.
2 hours ago - last edited 2 hours ago
Are the calls ending in 4001? If it is then you are calling your voicemail box. This is normal.
I wouldn’t worry about it if you have unlimited outgoing calls but if you are on the $15 plan then the call will be deduct from your 100 minutes/month.
