04-28-2025 11:39 PM
Hello!
I just checked my account for the first time in several months, and after reloading the subscription page, spotted a very conspicuous "60GB" right under my current 1GB plan (see image). It isn't there when I open the subscription page from another tab on the PM website, and only appears when I am on the subscription page, and reload. There is no other indication that 60GB exists in my account; I only have a 2GB add-on available currently, and have not purchased any extra gigs nor accepted any data promos.
Is this some wacky bug in the website? Have I been blessed by the data gods? Am I missing something embarrassingly obvious?
Thanks!
04-29-2025 05:52 PM
@Yummy - I believe it is something in the code that they just changed from the maintenance a few days ago which conflicted with the legacy 3G speed plans ($15 250MB 3G, $25 1GB 3G, etc.).
Anyone in QC or wherever they had it offered - the $15 250MB 4G speed plan?
04-29-2025 01:51 PM
Thank you so much everyone for your help! The mystery of the 60GB has been solved. 🙂
04-29-2025 10:17 AM
I had the same '60GB' on my $15 plan. Then it disappeared... I assume it was a glitch...
04-29-2025 01:07 AM
You're not the only one with the bug, I also found it. Public will probably fix it soon.
04-29-2025 12:55 AM - edited 04-29-2025 12:56 AM
@slusagm wrote:If you are paying $25, then I am pretty sure it is a big
Try login again using browser with incognito mode. Try also login with PM app
And ask PM to confirm . Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
Or message them using this link:
If the customer wants to discuss concerns with a CSA about the advertising, the customer can certainly do that, but there's no need to confirm the 60 GB aspect. The plan doesn't include 60GB. Having the the customer go through a CSA unnecessarily isn't advised.
04-29-2025 12:15 AM - edited 04-29-2025 12:18 AM
It's just a glitch / bug. I recently found the same bug in my $15 plan. I asked to have the 50GB's data dded to my account...you can imagine what they told me !
added my pic..
04-28-2025 11:50 PM - edited 04-28-2025 11:50 PM
