2 hours ago
I just purchased the 50GB Canada US plan. When I cross the border to the US, do I need to do anything like switching to a particular provider (ie. Verison, T-Mobile) or change any settings on my iphone?
48m ago
@mp1988 if your phone is an iPhone 8 or newer (running on iOS 16 & above) then your phone is already on the Public Mobile white list of VoLTE devices and therefore should be good with either T-Mobile or AT&T, but if it's an Android you can check the list below to see if your phone is whitelisted, note: even if your phone supports VoLTE if it is not on list the feature likely will not be enabled on PM's side. If you have issues with making/receiving calls but text and data works then you will need to connect to T-Mobile 2G for voice, AT&T will not work for voice in this scenario. Most people have had not trouble using their phones in the US.
If you get a message when you enter the US that says you will need to buy a roaming add-on, ignore this message as it seems to get sent out automatically to all customers
Scroll towards the bottom for a list of VoLTE-roaming enabled devices:
https://www.publicmobile.ca/en/on/get-help/articles/volte
2 hours ago - last edited 2 hours ago
T-Mobile/AT&T connect manually, turn off connect automatic. Turn off 5 g and put on 4 g. Make sure your roaming is turned on.
If the phone is not connecting to T-Mobile/AT&T, change the Network Connection from Automatic to Manual and select and test both T-Mobile and AT&T and see which one you can connect. Make sure VoLTE is enabled on the device setting. You can download VoIP app TextNow to make calls and text if your phone is not VoLTE enabled.
