3 hours ago
On a different number I used an old email which does not exist anymore. How can I regain access without using the old email?
2 hours ago
At the login screen I can click "Forgot email", but then an email is send to the email on the account. I do not have that email anymore and do not know which one it was. I'm stuck.
3 hours ago
@Cephas2 wrote:On a different number I used an old email which does not exist anymore. How can I regain access without using the old email?
When logging in, the should be options to have the 2FA code sent by either text message or by voice message. Access to actual e-mail address isn't actually required, but you'll need to still use the old e-mail address as the login/username.
