lost network
yumin1
i am recently unable to connect to network
@yumin1 - did you activate a public mobile SIM card and have a current plan with Public? If not, you can activate the SIM card here: https://publicmobile.ca/en/bc/portal/activation
EDIT, oh, well since you used the word 'recently' i guess you once had services...okay then. Can you try your SIM card into another compatible phone to rule out a device issue?
Sometimes just removing the SIM card, putting into another phone, then back to your phone can help kickstart things.
DDM69
If you would like help, please include some details for your situation and what you have tried so far.
@yumin1 is it on the same phone you have been using?
try to click Reset all network
and check if your phone is blacklisted
https://www.devicecheck.ca/check-status-device-canada/
if you have another phone around, test your PM sim there
will13am
@yumin1 , have you checked your account to confirm that it is in active status?
