04-01-2021 08:32 AM - edited 01-06-2022 01:38 AM
I used my email address for a PublicMobile account a couple of years ago, but I let the service expire.
I'd like to use PublicMobile again, using that same email address, but now when I try to login, I get message "login has been disabled". I don't have another email address to use instead.
04-01-2021 10:45 AM
If you have use your PM account for couple of years then you need a new PM SIM.
You probably don’t remember your old referral code. That way you get the $10 discount with the 1 free month service.
Why did you leave PM?
04-01-2021 08:41 AM - edited 04-01-2021 08:42 AM
Once you decide on an email address to use, make sure to register it for the current promotion which will get you your second month free!!!
Even if you don't activate before the deadline to register for the promotion, make sure to get your email address in before then - you can activate later:
https://www.publicmobile.ca/en/on/fs2020
04-01-2021 08:34 AM - edited 04-01-2021 08:36 AM
When you say "disabled", you mean the Public Mobile account/service hasn't been active for over 90 days? If so, then yes the service would have been permanently disabled, meaning you'd need a new SIM card to begin the process again.
You then should be able to re-use the e-mail address as it would no longer be affiliated with any Public Mobile services.
If not, you can set up an alias e-mail which can be used for you Public Mobile activation and have that alias e-mail go to your regular e-mail address.
Don't forget to use someone's referral code on the activation to save yourself $10.
Welcome (back) to Public Mobile!!!
