number suspended- can't remeber the login info
mrco
Hello
I have a PM number, it is suspended due to expired Credit card.
I cant remember login, password, etc.
I need help/guidance to reactivate the number,
Thank you
@mrco
Just click on the link I added on my post.
mrco
Hello,
I appreciate your prompt reply,
I haven’t explained the issue well, my apologies.
I dont remember the account for the number, I don’t remember when we have started using the number,
I dont have account for that number, I don’t remember how were we able to use it so far.
would you please be kind and provide me with a link to contact a moderator,
Thank you
@mrco
You can click on Forgot Email/Password and you will see the partial info.
If that fails then you need to contact a CS_Agent to help you login to your account and update your CC information.
Mxt
Hi @mrco
Please  send a message to CS-agents explaining the issue at the link below:
https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437.
