login and logout
Marius1
I need to change the PAP credit card info. for my wife. We are both Public Mobile customers. When I click on the saved website I have on file I am automatically logged in with my name and account saved password information (https://selfserve.publicmobile.ca).
I do not see anywhere on the web page where I can simply logout so my wife can login with her name and password (or vice versa). Is there a different website I should be using?
Kd202020
It took me a minute to find the arrow on the left that displays the left hand menu. When I did, it was nice and easy to find the logout option.
Thank you
Pal210
There is a "Logout" button hidden at the bottom of the left-hand side menu.
Hope this helps 🙂
@Marius1  You can also  use the new PM app to sign in on your wife’s account if using the same device . Or just use her device to login into the website on her account, and your device for log into your account . Then no need to clear caches  and use incognito mode private mode each time
hairbag1
@Marius1
can we assume you've already created an Eversafe account for wife ?...if not, you gotta do that.
HALIMACS
@Marius1
Try clearing cache and cookies and using an incognito tab to login.
