@mbollella59
If you tried too many incorrect password, your account will be locked for one hour.
You can try again in approximately one hour and then reset your password.
https://selfserve.publicmobile.ca/forgot-password/
If not working, you will need to customer service agent (CSA).
You will need to contact customer service agent (CSA):
https://www.publicmobile.ca/en/on/chatbot. Type: I can't login. Follow the prompts to submit ticket.
