log in problem
06-30-2024 03:33 PM
Hello, I've been member for almost 1 year and usually check my account through the mobile app.. no problems and usually it opens up directly to my account information and phone history. Today I tried to log into my mobile app and it asked for my email & password, no problems and when I put in my security code it took me to a screen asking me what subscription I'd like to purchase.. Not too sure what to do know. any help
Thank you
Service
07-01-2024 10:14 AM
yes, phone is still working
I send a message to CSA
thank you so much
06-30-2024 07:58 PM
@Badabing37 it looks like your emails may not be connected to your account,
Is your phone still working? If yes,
Send a message to CSA through the following link to look into th
06-30-2024 04:00 PM
@Badabing37 , if clearing app data didn't resolve the problem, I suggest using the chat symbol on the lower right corner of the web page and initiate a support ticket.
06-30-2024 03:56 PM
I've tried both and still no luck.... still keeps asking me to start a subscription
06-30-2024 03:47 PM
@Badabing37 Have you tried logging in with a web browser instead of the app?
06-30-2024 03:43 PM
Thank you for your quick reply: I deleted and reinstalled the new app but it keeps going to the same screen asking to select a subscription
06-30-2024 03:42 PM
Hey @Badabing37
This has happened to me before on my iPhone SE 2020. How I fixed that was to go into the settings, then went to applications, found the PM app and first cleared the cache, then cleared the data. I rebooted then tried to log in again and back in with no issues.
06-30-2024 03:35 PM
@Badabing37 , make sure you are using the latest app version, delete app data and try again.
