just moved from Telus
jatt
I have been with public Mobile just under a month what a improvement love the unlimited picture text and even a little bit of data is great I have found every thing running smooth
10 REPLIES 10
jatt
ya it works great glade I found this
@jatt @michelleocean
Glad you are enjoying PM’s service and pricing.
PM connects to Telus and Bell (shared) cell towers so coverage is good.
jatt
ya I don't need a lot of data so i think thi will do fine
jatt
Thank you I will
jatt
ya that right I us data very little
michelleocean
@esjliv that's a great point! Personally, I use very little data as I try not to be on my phone much so the $15 plan works great for me but I can see how it may not be ideal for heavy data users.
For more heavy data users, public mobile plans may not be as desirable; unless you take advantage of Rewards/Public Points. But, if you are more of a lower data user @jatt @michelleocean , I find Public Mobile a great fit !
Yummy
Another happy customer! Keep it that way but always remember - PM is not perfect and stuff could happen unexpectedly. Read forum for various issues customer have and be prepared not to panic if that happens to you too.
michelleocean
I just switched over a month ago too and am also very happy with the change! It's great to have so much freedom at a lower cost as well as a community to help answer any questions you may have.
@jatt  happy that you love it.
Yes, PM is owned by Telus but has plans on the lower price range.  So, you can save a bit of money while using the same great Telus network
Support model is different, but you found the right place.  Whenever you have a question, come here and post 🙂
