11-01-2023 09:35 AM
itinerancy in USA I got the money in the account the system won't hook me up
11-01-2023 10:12 AM
HI @Dzian1
do you have the Canada-US plan or the US roaming addon?
tell us what you have tried
Generally, you need the Canada-US plan or the roaming addon, then try to connect to T-Mobile or AT&T. But tell us how far you have gone
11-01-2023 09:44 AM
You need US add-on or Can+US plan in order to have service in USA.
If you have any of those connect manually to AT&T or T-mobile
11-01-2023 09:38 AM - edited 11-01-2023 09:39 AM
"the system won't hook me up" as to you cannot buy the US roaming addon or you just cannot connect?
To use US roaming, you must first go into your My Account and buy the US roaming addon you want (there are different ones)
Please login My Account using incognito mode and make the purchase first. Once purchased, wait a minutes, reboot the phone and try
To connect and use US roaming,
make sure you try to connect to T-Mobile and AT&T network. If it does not connect automatically, then change the Network connection to manual and select try T-Mobile and AT&T manuall.
If you roaming purchase includes data, make sure you enable Roaming Mobile Data on your phone. Change network mode to 4G/LTE
If your roaming purchase includes voice, enable VoLTE on your device and you might be able to use VoLTE for voice. But if not, your phone should change to 2G network on T-Mobile ONLY and test voice calls
11-01-2023 09:37 AM - edited 11-01-2023 09:42 AM
Have you purchased a US roaming add-on? If you go to the subscription and add-on’s section click shop add-on’s, then look in the US Roaming section. If you have already made a purchase reboot your device.
Make sure data roaming is turned on if you’ve purchased a data add-on. Make sure you are connected to either AT&T or T-Mobile. If AT&T doesn’t work for you manually connect to T-Mobile and reboot your device. If your device isn’t VoLTE roaming enabled with PM you’ll have to manually connect to T-Mobile for calls to work.
You can check the VoLTE roaming enabled device list here:
https://publicmobile.ca/en/on/get-help/articles/volte
If calling doesn’t work on T-Mobile try turning your voice and data setting to 2G/GSM.
