05-10-2023
01:32 PM
05-10-2023
05:05 PM
computergeek541
I'n an old customer, recently, i have had a problem signing in my account,
I tried with the passwords many times but it said it exceed the max attempt. and I also try to reset my password but never the resent email from the public phone after I tried several times.
So, is there any solution to my problem? Thanks
Thanks
05-10-2023 03:37 PM - edited 05-10-2023 03:39 PM
If you never received the 2FA code to your email address to change your password. This means that the the ID email address is not registered in the system and doesn’t match the email when you activated your SIM.
05-10-2023 01:36 PM
The website is finicky. If locked out, wait one hour and try again
When you attempt again, use a different web browser, clear cache or incognito mode. Or try on a different device (preferably PC or laptop)
05-10-2023 01:34 PM
@weishaoD did you check the spam folder ?
I suggest you to open ticket with support and have them help to confirm the email and reset the pasword
