Invoices
fbotca
Hi there,
How can I view/download my Public Mobile invoices? I don't find them anywhere under the "Payments" tab.
Thanks!
fbotca
Thank you, that was helpful.
fbotca
Thanks!
dabr
@fbotca   An invoice is only available for a short period after making a manual top up to the account otherwise you need to contact support and ask them for invoices.
Normally chatbot is recommended to contact CSA's but I notice some threads mention that it's not working ATM so you can send a private message instead to CS_Agent here:  https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
kappieCA
Hi There,
Under the payments tab, click the View Payment History link. Once there, you can apply date filters or by card. Once you have the correct date range, click the Download link at the top right hand corner of the page.
Thanks.
@fbotca
Yes, you can download the payment history on the payment history page
https://selfserve.publicmobile.ca/en/account/payment/payment-history
There is a Download link on the top right. But it is just a payment history that does not include tax
If you need official invoices showing tax, you will have to open ticket with support:
1. Please open ticket via Chatbot (requires access to My Account) using direct link: https://publicmobile.ca/chatbot.
Start by typing "Contact agent ", then click "Contact Us", then click "Other", click "Click here to submit a ticket ↗""
Next, enter your Community login, then enter your question.  Finally use My Account login or 4 digits PIN to validate.
