international travel
Johndeere1
Will my PM phone work in Europe.  Mainly looking of data usage.
HALIMACS
@Johndeere1
For clarity, @Johndeere1 , the DEVICE itself should work - depends on it's capability to pick up local towers and signals.  Before purchasing a pre-paid SIM card, make sure your device is compatible with their service.
The Public Mobile SIM card will be useless in the whole world outside Canada and the USA..
@Johndeere1  Public mobile won’t work in Europe, best to get a local SIM card for your destination . Cheaper that way anyhow
HI @Johndeere1   you will need roaming add-on to use your PM service in Europe, but PM does not offer roaming add-on there.  They only have roaming add-on for US
Look  for those data sim card in Europe, it's cheap and quiet a lot of choices.  Most work in many European countries.
Meow
Short answer is - NO.
PM does not provide service in Europe. Get free voip app instead.
 @Johndeere1   sorry, No.  PM does not offer roaming service other than US.
So, you will have to rely on local data prepaid sim instead
