travelling
Rebel1
Any suggestions when travelling to Mexico using public mobile as provider.  I am from Ontario.  Just noticed Public Mobile doesn't  have a plan for Mexico.  I should say doesn't have an add on for Mexico
saber_
No add on unfortunately.
Chalupa_Batman
Hey @Rebel1
It really depends what plan you have right now. For some who have a plan between $30-34 plan, upgrading to the $35 Can US Mex 60GB might be worth it to them.
However, if you have a phone that can do eSIM, here's an option. https://www.airalo.com/mexico-esim
slusagm
They dont have Mexico add-on, so Canada US Mexico is the only way.  But don't try to change to just 1 month for the trip only, you likely cannot change back to your old plan.  But if you like those roaming plan itself and want to stay with it, they are good
If it is a one trip only thing, use local data sim or travel esim
