@jaykwarren wrote:
Hello,
I am having trouble receiving and sending texts. I have had this problem since I started with PM in April 2017. I am using an IPhone 5 and it seems to happen to both android and IPhone users.
The problem may be related to the "waiting for activation" message. My PM number doesn't register with imessage.
HELP PLEASE!!!!
Hi @jaykwarren,
This might be something to do with your phone (iPhone I assume). Before you contact the Moderators, try the following:
1. In Settings, go to Messages and turn off iMessage. Then, in Settings, go to FaceTime and turn off FaceTime. Finally, reboot your device and enable the two options again.
If the above still does not solve it, then try:
2. Reset your network settings (Settings > General > Reset Network Settings)
Report back and let us know if this helps.
