05-16-2024 06:44 PM
Suddenly I can't send images over sms to Apple devices. I did change the stuff I had to do when there was that change to that a while back
05-16-2024 07:25 PM
hi @AlsoKnownAsDuff try Reset All Networks
And what phone you have??
05-16-2024 07:23 PM
@AlsoKnownAsDuff Images send through MMS and not SMS. Do you have send as MMS enabled, and data turned on? Did you recently do an Android or Google Messages update?
05-16-2024 06:49 PM
Hey @AlsoKnownAsDuff
My co-worker had that problem too. So I went into his settings, then network settings and turned off automatic. Then I picked Public Mobile then rebooted. From there it worked.
