07-06-2022
11:25 AM
07-10-2022
12:34 AM
Dunkman
Hello,
I am using all my data sending iMessages. I have tried to turn off iMessage etc but then nothing sends.
what steps exactly do I need to do to stop using data for texts? Do I need to restart phone after?
Is it even possible?
Ive tried to follow instructions in community, on apple site… all fails
07-10-2022 08:31 PM
This worked!!!! Thank you
07-06-2022 11:46 AM - edited 07-06-2022 11:47 AM
HI @Bunnybfunny
07-06-2022 11:45 AM
You should be able to toggle on send as SMS/MMS and toggle off iMessage.
07-06-2022 11:44 AM
PM has unlimited texting so you should be OK.
Go to Settings>Messages>enable Send as SMS. Also enable MMS Messaging if you are texting pictures.
07-06-2022 11:40 AM
The last option....does work. Look here.
