iPhone SE (2020)
07-17-2023 08:28 AM
Weak signal & data slow and sometimes not working even though I reside in a big City with several cellular towers nearby. Anything I can do? What are the correct APN settings?
Service
07-17-2023 11:50 AM
Upgraded to newer firmware to see if it helps. Also try this in different location to see if the weak signal is location problem
07-17-2023 10:08 AM
Have you had any work done on the phone that required it to be taken apart. It is possible that the internal antennae was not re installed properly.
Try a full reset of phone.
07-17-2023 08:32 AM
APN settings only helps when you not getting data at all. If weak signal, slow data , it won't help
check your phone and see which network you are connected to. Whichever plan you have, you can access 3G , 4G and 5G network. So, go to your network mode, try each one and see which one give you the best speed
