07-17-2023 11:39 AM
What is my PUK number?I can’t call any phone right now
My Account
07-17-2023 11:51 AM
What is the exact message the phone is saying? There are different things called puk.
07-17-2023 11:50 AM
what was the exact error message? Depends on the message, you have to ask the PUK code from different places
call Samsung 1-800-726-7864 for a master unlock code.
The only info you will need to provide is the IMEI and where the phone was purchased|
open message support there: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
or use this direct link to open Chatbot ticket: https://urlshortner.tiia.ai/Oyn1L6
**Monitor your Community inbox (envelope icon on the top right) after the ticket is opened. CS Agent will reply to you there.
If the message is "SIM network unlock PIN" or "SIM ME lock code NP" or "SIM not Supported" or on an iPhone's About->Carrier Lock showing "SIM locked"
You have to ask the carrier where you got the phone from for the carrier unlock code.
(Sorry, for this particular issue, PM support would not be able to help)
07-17-2023 11:48 AM
The PUK would be something you set on your phone but if you forgot the PUK.
Just contact a CS_Agent through private messaging on the envelope icon on your computer.
07-17-2023 11:42 AM
@Henry_Teh You need to get it from support
message support directly
while your already here and logged in the community you can send a private message To CS_Agents click
VVVVV Link below VVVVV
