02-19-2023 03:34 PM
I recently bought a pre-owned iPhone 11 online with Public two weeks ago. The hotspot connection keeps disconnecting after 5 to 10 minutes. I checked the battery saver and low-data mode are both OFF. I have another iPhone XS and don't have this issue. iPhone 11 have been updated to the latest OS. Can the issue be fixed or changed the iPhone? Thanks
02-19-2023 03:45 PM
I open a service issue with CSagent
02-19-2023 03:43 PM
I switched to another iPhone XS in the same location without any issue
02-19-2023 03:41 PM - edited 02-19-2023 03:41 PM
Perhaps the device hotspotting to it is connecting to an available wifi connection, thus terminating the hotspot connection.
Also tends to happen when device is out of Bluetooth range - can be wonky.
02-19-2023 03:40 PM
The phone is newly setup
02-19-2023 03:38 PM
@PYMak wrote:I recently bought a pre-owned iPhone 11 online with Public two weeks ago. The hotspot connection keeps disconnecting after 5 to 10 minutes. I checked the battery saver and low-data mode are both OFF. I have another iPhone XS and don't have this issue. iPhone 11 have been updated to the latest OS. Can the issue be fixed or changed the iPhone? Thanks
@PYMak - it sounds like you may have googled this to troubleshoot. Did you troubleshoot other items that are mentioned here?
Maybe try a Reset of your device's Network Settings and see if that improves the issue. This also resets Wi-Fi networks and passwords, cellular settings, VPN and APN settings, and connected Bluetooth devices that you've used before.
Iphone:
To Reset Network Settings, begin by opening the Settings app. Next, tap General -> Transfer or Reset iPhone -> Reset -> Reset Network Settings. and enter your passcode.
Your iPhone will reset network settings and restart itself.
02-19-2023 03:35 PM
@PYMak Take to Telus store to check warranty or ask support to return while still under the 30 day mark
Watch for reply top of page to the
Right ( envelope image )
