3 hours ago
The issue I'm having is that the personal hotspot only works intermittently. Connecting an iphone 11pro , ios 17.5.1 to an M1 16 inch MBP, sonoma 14.6. I've tried tethering/usb - this works sometimes out of the blue. I've tried untethered wifi- this also works sometimes but it can't be counted on. Any suggestions greatly appreciated!
an hour ago
on the iPhone where you are starting the hotspot
To turn off Low Data mode
Settings -> Mobile Data -> Mobile Data options
To turn off Lower power mode:
Settings -> Battery
an hour ago
Thank you for your reply. Are those settings on the phone or on the laptop?
2 hours ago
PM does not block or care you hotspot or not
make sure you turn of data saver and power saver
2 hours ago
This is feature of your phone and nothing to do with PM.
3 hours ago
@instantplaces Maybe try updating the iOS to the latest 17.6 also see if that helps maybe
3 hours ago
Try resetting the Network Settings and try again.
