Personal Hotspot
Saintrae
I can’t connect to my personal hotspot.
2 REPLIES 2
Chalupa_Batman
Hello @Saintrae
For me, I just go to my WiFi, I see my Public Mobile phone which is an XR with no issues. Might need to reset your network settings by the sounds of things and try setting it up again.
How to set up a Personal Hotspot on your iPhone or iPad - Apple Support (CA)
Hi @Saintrae
PM does not block hotspot
make sure your phone has the latest iOS and Carrier profile., reboot phone, click Reset network settings and test again
if that does not work, maybe try your sim in another phone and test again
if you can confirm hotspot really does not work on 2 different phones, ask support agent to check the account
 please submit a ticket with CS Agent using this Chatbot link:  https://widget.telus.tiia.ai/publicmobile/publicmobile.html  Type the question "Submit ticket", Then click the following in order: "Contact Us" ,  "Other",  "Log In".
If any issue with ticket submission, you can  submit by direct message:
