10-05-2023 01:22 PM
Hi everyone, new to PM here. Just set up my account yesterday but am having trouble sending videos via iMessage (both on WiFi and cellular data). Regular text messages via iMessage work fine. I’ve turned iMessage on/off and also turned WiFi on/off with no fix. Also turned the phone on/off and have software up to date. Any ideas?
Service
10-07-2023
02:33 PM
10-15-2023
09:16 PM
Luddite
It ended up being an issue with my eSIM. Customer service assigned me a new one and everything has been resolved.
[✅ seems odd a disfigured eSIM can affect wifi too; live and learn ....... Luddite]
10-07-2023 12:39 PM
Hi all, I have reset network settings etc but have now been waiting a day and half for my phone number to be activated. I see a “waiting for activation” message in my messages settings. I have reached out to customer service.
10-05-2023 01:54 PM
@felix_felicis wrote:@Yummy videos are not sending via cellular data either…
I know. NORMAL phone uses native texting app and SMS/MMS are sent through cellular network.
When somebody uses 3rd party app they have to figure out WHY it is not working. Nothing to do with PM.
10-05-2023 01:46 PM
Check your iPhone setting to see if Send as SMS and MMS Messaging are both enabled.
Go to Settings>Messages>scroll down to SMS & MMS.
10-05-2023 01:32 PM
10-05-2023 01:29 PM - edited 10-05-2023 01:29 PM
Sorry, nothing to do with PM. If ALL other services work (native phone and SMS) then It is apple's stuff so you have to talk to apple.
10-05-2023 01:28 PM
Hi @hTideGnow, thanks for the quick reply. I will try this. Can you tell me where I find the “reset network settings”?
10-05-2023 01:26 PM
if it has problem with Wifi, it is not a problem with PM.
You can go to your iMessage, remove the phone number first, then reboot the phone, click Reset Network Settings, then the add your phone number back in iMessage
