Cannot send or receive SMS or iMessages
weissb
Hi, I switched to Public recently and since porting my phone number from previous provider, I have been unable to send or receive SMS or iMessages. Support has “reset my network settings” but nothing has changed. I have restarted the phone multiple times, reset all connections, etc.  Any suggestions?
2 REPLIES 2
@weissb
Check if MMS and SMS is enabled in the phone settings.
Go to Settings>Apps(on new phones)>Messages and enable MM Messaging and Send as Text Messages.
You can also enable RCS Messaging if your iPhone have this option.
Then reboot your iPhone by powering off then back on.
If it still doesn’t work then click on Chatbot and type in Submit a Ticket or Contact Agent for them to check the issue.
hi @weissb you receive inbound calls without problem?
make sure Carrier Profile is updated
then go to iMessage Settings, remove the phone number a d reboot.  After phone is up, go back to the iMessage settings and put the number back to re-register
