i can't send or receive picture messages
11-21-2019 09:53 PM - edited 01-05-2022 08:04 AM
11-22-2019 10:34 AM
@gph22 Make sure data is turned on and that APN Type contains mms if you are using an Android device.
If you have an old iPhone then it won't work.
11-21-2019 09:56 PM
@gph22 Which phone are you using?
You may need to configure the APN settings as follows
https://apn-canada.gishan.net/en/apn/public-mobile
Restart phone after changes.
Enable data on your phone.
11-21-2019 09:56 PM
For picture messaging, you need to have data turned on and set up properly. Does your data work?
Might need to check your APN settings....
APN: sp.mb.com
Proxy: Leave blank
Port: Leave blank
Username: Leave blank
Password: Leave blank
Server: Leave blank
MMSC proxy: 74.49.0.18
MMS port: 80
MCC: 302
MNC: 220
APN protocol: IPv4
APN roaming protocol: IPv4
Bearer: Unspecified
MVNO type: GID
MVNO value: 4D4F
