12-19-2023 09:15 AM
12-19-2023 10:06 AM
THANKYOU FOR YOUR HELP. iT HAS BEEN A NIGHTMARE FOR US TO UNSUBSCRIBE
12-19-2023 09:22 AM
To "discontinue" the plan, you can either port out your number to another provider and your account will be closed upon successful port out of the number
Or you can disable the toggle "Subscribed" to disable Pre-Authorized payment instead. Once it is disabled, PM will not be able to renew your account on your next renewal , your account will then be suspended on that day and 90 more days, it will be closed
To disable Pre-Authorized payments (Turn off Subscribed) , you can do it by one of the following:
https://myaccount.publicmobile.ca/en/account/my-payment/manage-subscription
12-19-2023 09:17 AM - edited 12-19-2023 09:17 AM
@sueG First way is to port your number out second way is to turn of auto pay
Turn auto subscribe off/on
Or if you know the 4 digit PIN number
*611
and finally third way is to get support to remove the credit card info on file right away
send a private message To CS_Agents
⬇️⬇️⬇️⬇️⬇️Link below ⬇️⬇️⬇️⬇️⬇️
