11-18-2024 06:32 PM
11-18-2024 07:01 PM
Just a heads up @WorkKing , if you can hold off a bit longer, Black Friday offers are just around the corner. Might be better offers then than now. Just my opinion.
11-18-2024 06:54 PM
back in early summer '24, PM offered some new, more expensive plans but forgot to tell anyone that it would be difficult to find cheaper plan once you've opted for one of the new plans. On top of that, PM took away the traditional Rewards in favour of less desirable points. Many have reported that they're going to migrate to cheaper cell networks, as a result of these negative changes to PM.
11-18-2024 06:34 PM
Sorry @WorkKing , you won't see all plans on your My Account. Some plans are new activation only. And PM also offer some plans directly to some subscribers but not all
You can only change to plans available on your My Account. And remember to use Change on Renewal option if you don't want to waste money
