02-07-2018 09:13 PM - edited 01-05-2022 04:05 AM
@Moderator_Team My usage says that I am making calls to 9025804001 but there is no way that I am making these calls? Is this a scam or just lax security with Public Mobile?
Service
06-19-2018 07:45 AM
I am not complaining, although it may sound like it. For my needs, the 50-50 is still the very best available with any carrier. It's really the spam calls that got me annoyed.
06-18-2018 09:29 PM
You’ve said you’re on the 50/50 talk and txt limited plan. This plan charges minutes when you use your cell phone to check voice mail. It’s in the contents of the spoiler area, of the first post in the thread announcing that plan.
if you want free access to your voicemail, either use the suggestion I’ve provided for you, or change your plan to an unlimited talk option, being one of Province, Canada, or Canada and US calling.
06-18-2018 09:23 PM
Although I really do appreciate the tip, especially the how-to part, more often than not, doing so would prevent quick acess to voice mail. Can't have your cake and eat it too, I guess.
06-18-2018 09:14 PM
Check your voicemail from an unmetered phone number, such as a landline.
To do so, call your cell number, and when the greeting starts, press #.
06-18-2018 08:21 PM
Great...I am on the 50 min 50 text plan, which is great for my needs.
But...I get a voicemail from an unknown number and get charged to go to voicemail to find out that it is a phone scam call. What's wrong with this picture?
I suppose it is PM's way of preventing me from receiving a "free" message?
05-28-2018 11:34 PM
We are talking about calls TO an unknown number, whereas you are referring to calls FROM an unknown number.
02-09-2018 03:12 PM
wrote:Well I was really commenting to say that it seemed funny that I had mentioned it as being the possible problem... but the OP selected yours as the answer. I'm not looking for a correction, as I'm here to help.....just thought it was funny.
It's okay... I got overlooked again today when an OP responded with a 'thanks for the input' post, and selected their own post as the solution.
Dems da breaks!!
:0 no worries, I certainly do not want to bathe in someone else's glory.. 🙂 Lets hope mods correct the mistake 🙂
02-09-2018 03:08 PM
Dems da breaks!!
02-09-2018 03:00 PM
wrote:Congrats to @MVP for the solution... two posts after someone else called it 😉
Dem's da breaks.
:0 @stonechucker if ure implying that I was unfairly granted a "solution" badge (were I?), because your post was before mine,
I'm all for correcting that mistake. Mods, please award @stonechucker with the solution badge instead! 🙂
02-08-2018 02:52 PM
02-08-2018 01:08 PM
Hey there @lkg4ansrs,
That phone number is simply your voicemail number. Normally the area code (902 in this case) matches the province you are in.
If you want, you can send us a private message with your phone number and PIN so we take a look at this for you 🙂
Saray
02-08-2018 12:58 PM
You don't know if it's AM or PM because there is no designation of such in the usage history, and it is also not a 24 hour clock.
WEB data is reported twice a day, and I don't send text messages regularly before 8 am, so I know the ones listed for 6 - 7 o'clock are in the evening.
Another failure of the usage history information display.
02-08-2018 12:52 PM
could it be the timezone difference that got messed up?
02-08-2018 12:19 PM
02-08-2018 12:07 PM
@lkg4ansrs at least a couple of possible explanations:
1) Your phone didn't have signal at the time the call came through. Since this is happening in the middle of the night, it's possible your phone has gone into some sort of deep sleep mode and isn't waking up properly to receive the call? What phone is it, and what verison of your respective OS (iOS or Android)?
2) Have you added any numbers to your blocked calls list on your phone? If you have, they are immediately redirected to your voicemail without rinigng through. I just had a look at the call history on my phone (OnePlus 5T running Android 8.0.0, previously 7.1.1 when I last had a blocked call) and it doesn't show the blocked calls. That said, my phone DOES give me a notification in my notifications area when it blocks a call. It's possible yours doesn't?
02-08-2018 11:29 AM
I would have a number on my phone that shows an unanswered incoming call.
02-08-2018 11:20 AM
wrote:Nope. Didn't receive a call at 5am or close to the time my voicemail made a call.
How did you know if you havent answered it?
This patticular aspect of public voicemail functioning was confusing to me too...
02-08-2018 10:37 AM
02-08-2018 10:31 AM
wrote:From talking to others using Public Mobile, looks like it's voicemail. Still not sure why my voicemail makes calls at 5am while I'm sleeping though!
Exactly because u did not answer, and your phone automatically called out your voicemail number?
02-08-2018 10:21 AM
02-08-2018 06:45 AM
wrote:@lkg4ansrs, this looks much like the voicemail access number on my cell phone. Could these be everytime you call voice mail to check a message?
Mystery solved. I wish I could bravo this more than once!
02-08-2018 02:04 AM
People and companies who do not want you to know who they really are use faked phone numbers quite often. This can be telemarketing firms or flat-out sometimes even people trying to scam you.
One of the tricks that these people will do is make the call display show a number that is similar to yours (or even the same) in the hope that you will answer the call.
However, I've found that most of the time when I receive incoming calls supposedly from a phone number that starts with the same set of phone numbers as mine, I know that it's almost always a b.s. call.
02-08-2018 12:42 AM
@lkg4ansrs..... I just checked on my phone.... change the 902 to 226 and I have the same number as you. My number is in area code 226, so I would assume you’re in area code 902, or within normal local area calling of the 902 area code.
02-08-2018 12:41 AM
It is voicemail, people! 🙂
02-08-2018 12:35 AM
02-07-2018 10:53 PM
Spoofed phone numbers (and "phone phreaks", the predecessors of modern "computer hackers") were common in olden times. I wouldn't be surprised if technical methods still exist to "borrow" or "fake" other people's phone numbers today. Though I honestly can't imagine how this would be done remotely, unless these calls/numbers are injected into or intercepted within the system from the "inside". Or it's just an innocent typo or an inconvenient billing error.
But on the device itself ... my immediate suspicion is that your phone is running some sort of spyware or malware. There's probably downloadable tools to clean it up, but it would probably be better to simply erase/reset the phone completely (after backing up anything you want to save). There's also task-manager or task-killer apps which can help you monitor and control exactly what's running "in the background", but they're not guaranteed to be fully reliable for this purpose unless you've rooted the phone and allowed them to have "full" priority (alongside the operating system itself) above other installed/running software.
But yeah, inform PM of the details, they may need to monitor or investigate (or report) some sort of potential abuse. And change your PM passwords - in fact change every password you've submitted through your phone - just to be prudent, probably unrelated to this other mysterious issue but it might halt potential problems you wouldn't want to deal with the hard way. Maybe request a new PM SIM card, too, again just to be prudent.
Their has been much talk about a "new" vulnerability called "SPECTRE/MELTDOWN" which could theoretically exploit phones with ARM processors in this way (and many other ways), but unless your issue is reported by hordes of people in the near future then I seriously doubt it's at all relevant. It's certainly irrelevant if the dates these calls were made are earlier than the date this (potential) vulnerability was discovered.
02-07-2018 10:30 PM
Will do that. Thanks.
02-07-2018 10:26 PM
@lkg4ansrs, this warrants investigation by the moderator team. I suggest sending them a private message with account details. Even if they read this thread, they will ask for private message communication anyway. Use this link to private message the moderator team. Refer to the following link for information on contacting the moderator team.
http://productioncommunity.publicmobile.ca/t5/Knowledge-Base/Updated-Contacting-our-Community-Modera...
02-07-2018 10:23 PM
I for sure don't know anyone in Nova Scotia
02-07-2018 10:21 PM
That number is not in my phone's call history.
