My data is not working
Tooba-80
My data is not working at all ... i have a plan with 10 GB data but it's not working at all...also I'm not getting caller ID when someone calls me even if there number is saved ... it says unknown...please help me
7 REPLIES 7
@Tooba-80 S22 would work without problem
Make sure your remove old sim card or disable old esim.    And then Reset network settings once more
Of course,  check with PM if still unable to make it work.  But you have to open ticket so they will look into it
Tooba-80
I have the samsung galaxy s22 ultra
CSA_PM
Customer Support Agent
Hello @ Tooba-80,
You need to open a ticket and an agent will check and investigate the issue.
Please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket.
@Tooba-80
i have helped to escalate your issue with PM support.  Please monitor your community inbox for PM's reply
Tooba-80
Thanks for your reply I tried setting up the apn and restarted my phone and made sure the wifi is off but still data is not working I'm using s24 ultra please help me
@Tooba-80 what phone do you have?
You need to click Reset network settings once to make both data and caller ID work
But if that does not resolve the issue, ask PM CS agent to re-provision your account
Please open ticket with PM support:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
    Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Log In", finally click "Click here to submit a ticket ↗
hairbag1
@Tooba-80
in the Settings of your cell, can you see if Cellular Data has been enabled please.
