free giveaway minutes
Francie
Hi. I asked for the $0 Free Holiday Giveaway: 500min INTO Long Distance incl CA & US, but when I ran out of my 100 regular minutes, I couldn't call long distance in Canada any more without buying 500 more minutes. How do I ask my account to start using these free 500 minutes?
10 REPLIES 10
rhkjcfp
Thanks for
Mayor / Maire correction.
Post edited
Francie
Have to leave now but will try that when I get back.  Thanks for your help.
@Francie wrote:
That was the next call - a long distance one.  But I only had a few minutes left of the minutes I had bought and it wouldn't go through, despite the giveaway 500 minutes sitting there.  I checked the add-on page, but it's no longer available since I already added it on...  Now I'm at the end of 500 minutes that I had to buy and am wondering if I need to do anything in order to have those giveaway 500 minutes click in this time.
@Francie I would try restarting your phone. If that doesn't work contact a moderator for help at the link below:
You should receive a reply within 48 hours though typically they are much faster. Watch the envelope icon top right for a reply.
Francie
@Francie wrote:
Thanks.  Yes I did 'buy' them after picking them, and they are on my account.
@Francie Try adding a 1 and area code if you haven't already tried it. All of my contacts are saved this way.
Francie
@rhkjcfp   Just a slight correction, this year the international mins gift is 500 mins.. 😊
rhkjcfp
To add these add-ons to your account:
  1. Log into your Self-Serve account
  2. Click “Purchase Add-Ons” in My Data & Add-ons section of Overview tab
  3. Select the Free Holiday Giveaway: $0 1GB Add-on and/or Free Holiday Giveaway: $0 500min INTL Long Distance (incl CA & US). It’s up to you if you want one or both!
  4. Click “Buy Add-Ons” at the bottom of your screen.
You don't "ask" for them. You "purchase" them under Purchase Add-ons.
If you see the $0 holiday gifts under your data & add-ons area of your overview page then maybe restart your phone.
kb_mv
@Francie Are the free minutes showing in your account overview page? If not, go in and select them again in "buy add ons" and then select buy.
