esim not working
DanaCR
why will no one help me
szu
@DanaCR
Then you might need to contact customer service agent.
Click on the chat icon on the right lower corner of website.  Follow up prompts to submit a ticket.
If having difficulties submitting a ticket, you can also send private message:
DanaCR
ive done all that
hi @DanaCR
so, you have iPhone?
is Public Mobile the only esim on the phone? if you have other esim, please disable them, if you have another physical sim on the phone, remove it first.  After you done that, restart the phone again
DanaCR
its not giving me the option to make primary but its on
HI @DanaCR
you have us to help.
So, did the esim every work? or you just installed and weren't able to get it working?
Go to Sim Manager or Settings->Cellular and check if the esim is installed there and if it is enabled (or on iPhone, you have to make sure it is primary and enabled Turn on this line)
if enabled, try Reset All Networks
