04-04-2021 09:02 AM - edited 01-06-2022 02:27 AM
incoming calls are directed to old magic jack before ported to public
also i can text within public mobile network but for example i cannot use authenticator to receive verification code for important tasks. meanwhile i use the outgoing calling without any issues. keep in mind whomever calls i do not hear the phone ring its routed back to magic jack vocal message---and i do not have access to mailbox anymore
04-08-2021 02:30 PM
sorry this solution is not accepted andnot resolved. the phone was ported succesfully the first month and then the secondmonth i got different number.
case not solved---moderatorplease fix this i sent you all screenshots i wont waste anymore time here on this====just will delete account remove autopay.
thanks everybody but this was not reso;lved
04-07-2021 05:21 PM
YEP thanks
ghost 👻 This emoji shows a white ghost making a silly face, with its tongue sticking out. 👻 Ghost is a fully-qualified emoji as part of Unicode 6.0 which was introduced in 2010. Other related emojis include 👹 Ogre, 👺 Goblin, 👻 Ghost, 👽 Alien, 👾 Alien monster, 🤖 Robot, 💩 Pile of poo, 🤡 Clown face.
04-07-2021 05:20 PM
go see rosie note from moderator
attemting new port as we speak
but i cant reacive text
04-07-2021 05:18 PM
04-07-2021 05:14 PM
Thank you for contacting Public Mobile
I checked the status of your port for number 514400 BLABLA and it shows canceled.
When a port is initiated, a message is sent from the provider who has the number
To verify that the port is a valid one. (you need to his SIM card from your previous
Service provider in your phone)
You need to answer "Yes" to that message to validate the port and continue the process.
I will resubmit the request. Please Answer the test message so that the port is completed
If you cannot answer the message you have 90 minutes to contact your previous service
provider and let them know you authorize the port and they will release the number
Sincerely,MODERATOR
04-07-2021 04:57 PM
@dboxtvinfo715 if you call back the "new" number, would your phone ring?
04-07-2021 04:56 PM
@dboxtvinfo715 wrote:GUESS WHAT---I PORTED A NUMBER BUT NOW SHOWING DIFFERENT OUTGOING CALL NUMBER THIS EXPLAINS WHY I DO NOT RECEIVE CALLS, ITS NOT MY PORTED PHONE 514 400 NOW 438 SOMETHING
@dboxtvinfo715 oh no! definitely contact the moderators to fix this for you.
Welcome to Public Mobile
RosieR
04-07-2021 04:45 PM
04-06-2021 11:50 AM
yes patience in my late replies, while updating i do have outgoing calls no biggy
04-06-2021 11:48 AM
well i can do outgoing calls only, working on updatess
04-06-2021 11:31 AM
@dboxtvinfo715 30 days is a bit too many. Did you check your email? I know sometimes they have trouble porting landline and PM will email for more information.
.. but since it's 30 days ago, it's best to contact Mod to confirm. I assume you will have to re-request porting
04-06-2021 11:15 AM - edited 04-06-2021 11:55 AM
@dboxtvinfo715 wrote:incoming calls are directed to old magic jack before ported to public......the phone ring its routed back to magic jack vocal message
MagicJack VoIP service is considered a land-line based service, and because of that the number port for incoming calls could take a week or more, and will require considerable patience but it should eventually complete. You are in the right hands by confirming current status with the Moderators. Just don't cancel your MagicJack service until you have confirmed that incoming calls are now arriving on your Public Mobile phone - the "losing carrier" account must be active for the port to succeed.
04-06-2021 10:03 AM
@dboxtvinfo715 wrote:PHONE PORTED 30 DAYS AGO
Then moderators are needed to help. One week maximum for VOIP or landline porting.
Might want to contact Magic jack customer service to see whether Magic jack is holding things up for some reason.
04-06-2021 09:50 AM
04-06-2021 09:49 AM
magicjack.com
i had it ao years its a VOIP VOICE OVER INTERNET PROTOCOL====I ACCEPTED SOLUTION BUT MY PHONE STILL IN HANDS OF MODERATORS
04-06-2021 09:47 AM
internet voip magic jack
04-04-2021 02:08 PM
One of the original cheap calling options.....
04-04-2021 09:44 AM
How long has it been when you ported?
Mobile ports take a few hours to complete. Landlines and VOIP service like Magic jack can take a couple of days to complete (sometimes longer).
You should be able to call and text out, but unable to receive calls or texts.
04-04-2021 09:43 AM
Hi there...so did you just recently activate with Public Mobile? I ask because your Community account was created in 2019. But it is very likely you activated another new PM account.
huh, never heard of Magicjack.
If you just ported your phone number from another cell provider it could take a few hours to complete the port. Using the other cell provider's SIM you should be still receiving calls on it, until the port completes.
If you ported from a landline it could take up to 7 days to complete.
Make sure you do not cancel your previous provider's services until the port is complete.
Incoming calls are usually the last to port over.
04-04-2021 09:31 AM - edited 04-04-2021 09:31 AM
@dboxtvinfo715 wrote:keep in mind i do use it for outgoing calls.
noted ipretty much followed all your advice so far---should i accept solution , thank you have sent moderator email meanwhile
You're welcome - it's your choice whether to accept my reply as a solution.
But sure, I'd like that. Thanks!!! 😁
04-04-2021 09:29 AM
Is this site below of any additional help - truth be told, I've not heard of this provider, however their porting FAQ may assist:
04-04-2021 09:28 AM
