11-01-2024 05:10 PM - last edited on 11-02-2024 11:16 AM by Dunkman
I subscribed to public mobile n paid the fees n when the rain down loaded it it said active but it did not work , What can I didn’t now to fix the situation
11-03-2024 11:27 AM
@Rob12122002 wrote:Yes i ported a number over n yes. There was a QR code sent to my email the eSIM said connected but did not work no service so I deleted it n tried QR code n it ses it can’t be used .
Then you will need to contact customer service agent as describe earlier.
Then you will need to directly private message CSA:
Note: it will take 1-3 hours for CSA to typically respond to your request.
11-02-2024 07:43 PM
11-02-2024 11:18 AM
Did you port over a number?
Did you receive the email from PM with a QR code to install eSIM?
11-01-2024 05:23 PM
HI @Rob12122002
make sure the esim is active and set as Primary and "Turn on this line" is enabled
then try Reset All networks
if same, ask PM support to refresh the account or help to get a new esim. Message them
