03-08-2024
12:15 PM
03-08-2024
03:40 PM
computergeek541
Hey, basically, I purchased a plan with an eSIM card because during the payment, it said that my IMEI number was compatible.
But when I downloaded the app, it said that it wasn't compatible.
So my question is : Can I just go purchase a SIM card, put it in my phone, go to the app and activate it? Or will it still ask me to activate my eSIM instead? Is the plan I purchased only related to that eSIM?
03-08-2024 12:31 PM
Alrighty, I'll do that then! Thank you!
03-08-2024 12:30 PM
@qubn If you plan to port number over to PM from Roger’s do t cancel it . It need to be activate to port to PM . Once successfully ported to PM it will automatically close your rogers account
03-08-2024 12:25 PM
I checked online and apparently the canadian model of my phone doesn't support eSIM's.
I don't even see that option in my settings.
How long does it usually take for the support to answer tickets? I wanted to go purchase the cards and cancel my Rogers account at the same time. But I don't think that will be possible.
03-08-2024 12:22 PM
there is a chance the Public Mobile esim is already installed and just not properly enabled
On Android: Check your Sim Card Manager and see if a Public Mobile eSim is there. If so, make sure it is enabled.
On iPhone: check Settings > Celluar and see if the eSIM is there. If it is, make sure the PM eSIM is set as Primary on "Cellular Plan Label" and "Turn on This Line" is toggled on
And if the Public Mobile eSIM is there, disable or delete those non PM sim (eSIM/Physical sim).
If the non-PM sim is physical, remove it. If the non-PM sim is an esim, disable using the SIM Manager on the phone (or set as Secondary and turn off "Turn on this line" for this non-PM esim)
Then reboot the phone and click Reset All Networks on your phone and it will work. (Please note that Reset all Networks will also erase your saved Wifi and Bluetooth connections, but you just need to add them back after). Also, it is possible you have to reset it multiple times for it to work.
if it still does not work, open ticket with PM support using Chatbot:
1. Open ticket via Chatbot (need access to My Account): At https://widget.telus.tiia.ai/publicmobile/publicmobile.html
Start by typing "Submit a ticket", then click "Contact Us", then "Other", then "Login" and finally click "Click here to submit a ticket ↗"
2. If you have trouble with Chatbot or you don't have access to My Account: Private message CS Agent at:
03-08-2024 12:21 PM
HI @qubn
you can. Get a sim and ask support to update the sim number
But check again the esim setup on your phone. check Sim card manager and is it active? or set it as Primary and make sure "turn on this line" is set
03-08-2024 12:21 PM
@qubn @Yes you can change from eSIM to physical sim and I urge you to do so as I prefer physical sim anyways . Far more Benight’s ti physical sim . But since the account hasn’t been activated yet . You will have to ask Support to sim swap the number for you once you have SIM card in hand .just
submit ticket with support . using the chat bubble bottom right of screen
If that doesn’t work you can always send private message to support .
send a private message To CS_Agents
