03-01-2024 10:24 PM
hello!
do you know if changing the plan will also change the rewards type? With the current plan I'm accumulating dollars for autopay, referrals, loyalty and now i want to change to this:
any thoughts? thanks
Rewards
03-08-2024 12:45 PM
Wow these posts aged poorly.
You get screwed either way now.
03-01-2024 10:30 PM
no worries, you will still be on the old rewards system with plan change.
the reason you see those $1.70/month in points is because it is a marketing target for people who newly join and will be on the new rewards system
03-01-2024 10:26 PM
@nick_dv No you will keep your rewards the same. Their ties to your account not your plan . I can confirm . I just switched to new plan and kept my old rewards
