Rewards not added
Jan11
I added data to my account using my rewards but no data has been added to my account
2 REPLIES 2
Jan11
I did receive  the data on my account. Thank you. The issue has been resolved.
slusagm
Did you get the correct Canada data or US roaming data?
Login My Account using browser with incognito mode, click Usage Breakdown under the Usage odometer and check if the add-on is there
If it is not there and if you need PM to help, open a ticket. Just open ticket with PM using the Orange Chatbot icon on the lower right. (For 2FA when login, you might need to use email to receive if you cannot receive the text on the phone.) Type the question Submit ticket and select Contact Us to get to ticket open screen
But if you have trouble with open ticket using Chatbot, then message them using this link: https://productioncommunity.publicmobile.ca/t5/notes/composepage/note-to-user-id/22437
CS_Agent will reply to your community inbox, check here: https://productioncommunity.publicmobile.ca/t5/notes/privatenotespage
