Tuesday
Tuesday
Thank you. That has worked
Tuesday
HI @Jasonlutz
to resolve the issue, you have to use PM app to re-buy a new esim (but it is free)
use the PM app, login , go to Account page, and Buy sim card and choose esim
the system likely will charge you $5. Pay first and ask PM to reimburse after
to ask for reimbursement, please submit a ticket with CS Agent using this Chatbot link: https://widget.telus.tiia.ai/publicmobile/publicmobile.html Type the question "Submit ticket", Then click the following in order: "Contact Us" , "Other", "Log In".
If any issue with ticket submission, you can submit by direct message:
Tuesday
@Jasonlutz Do you mean on top of the phone it dosent show Public mobile ? If you have wifi on turn it off then it will appear
Tuesday
we reset network settings. Still doesn’t show anything on the bars, for network connection on the main screen
Tuesday - last edited Tuesday
@Jasonlutz You just tapping reset not erase all content and settings
Adding @Jasonlutz
Tuesday
We did this and now it says ready for your new iPhone. Your data is ready to be moved. I’m concerned if I do the next step it will wipe my whole phone and not work at all.
Tuesday
@Jasonlutz Go to settings > general and at bottom of page you see transfer or reset phone tap it
And tap reset
Tuesday
iPhone 14.
Tuesday
@Jasonlutz What phone do you have ?
Tuesday
How do I restart my network settings?
Tuesday
Hi. I have the eSIM working & on my phone.
Tuesday
hi @Jasonlutz
try reboot the phone, check sim manager or settings - cellular and make sure PM eSIM is there and enable
Tuesday
@Jasonlutz try Resetting your network settings
