eSIM not activating
Ing1
Why is my eSIM not activating?
My phone should be compatible for eSIM- iPhone11. What number can I call for further assistance?
Ing1
Unable to Activate eSIM
you can try again or contact your carrier for assistance
Ing1
All good now, thanks
@Ing1
Did you get to the eSIM installation step?   Either the app will ask for your permission to do it for you, or you can get the QR code to install yourself.
If you missed the step to install by the app, there is a QR code in your Welcome email.  Open it from a computer, or another device, then use your phone to scan it to install the eSIM profile on your phone.
Once you installed the eSIM profile, (or If you got passed that step eSIM installation step), try to reboot your phone once.
If it still does not connect and if you have another active sim on the phone, disable those non PM sim (eSIM/Physical sim) using the SIM Manager on the phone or simply remove the physical sim.
And make sure the one associated with PM sim and your phone number is enabled.
(On iPhone: Settings->Cellular , make sure the PM eSIM is set as Primary on "Cellular Plan Label" and "Turn on This Line" is toggled on)
Then click Reset All Networks on your phone and it will work.  (Please note that Reset all Networks will also erase your saved Wifi and Bluetooth connections, but you just need to add them back after). Also, it is possible you have to reset it multiple times for it to work.
if it still does not work, please open ticket with PM support
HI @Ing1
check your phone's Collular menu and see if PM eSIm actually there.  make it Primary and enable turn on the line
if not, please submit ticket with CS agent
TheSterlinger
What message do you get when trying to activate your eSIM?
