01-18-2024 11:09 AM
I signed up yesterday for a subscription however the eSIM was unable to be activated. I tried using the QR code numerous times however it didn’t work either. I was unable to submit a ticket as well. How can I get an eSIM to be activated?
01-18-2024 12:44 PM
@Loops It’s normal for the agents to ask those question in order to verify you are the true account holder
01-18-2024 12:43 PM
OMG! After spending hours trying to get it activated I finally figured out how to set it to turn on, thanks to your photo above . I had looked at it previously, but didn’t click in the right place. I had tried private message with Public, but found it very dodgy as they were asking for my PIN, and credit card details. That didn’t seem comfortable to me. What’s up with that. Thank you for your help!❤️
01-18-2024 12:23 PM
01-18-2024 11:20 AM
@Loops you can Maybe try resetting network settings and see if that helps . This will delete saved wifi passwords but you just need to re enter them
01-18-2024 11:18 AM
Yes, I did check settings and it was set to primary. There is no setting to click on enable. Thank you for replying. I’ll try private support
01-18-2024 11:12 AM
@Loops First check you sim manger in phone setting see if it actually installed already . And enable it or set to primary . If still no
luck you can use this direct link to support
send a private message To CS_Agents
