eSIM Port issue.
fixin1
Hello, I have an issue.
Porting from TELUS to Public Mobile, I have an issue.
Activating eSIM is stuck with SOS Only.
Should I contact CS_Agent or wait a bit. The port was 10 mins ago (4:00PM MST)
Also forgot to mention that TELUS SIM is fully deprovisioned.
@hairbag1  I’m guessing it’s the $29 or $35 MEX plans unless there’s something else out there k don’t know about
@fixin1 wrote:
nvm, it transferred. Just overeating. Got the "Secret" plan... for those who know...
So...what's the "secret" plan ? You can tell me and I won't tell anyone else....really I won't. 🤞
@fixin1  I would try to reset  network settings and of course check sim manger to ensure eSIM is set to primary /enabled if iPhone that you toggle on “turn on this line” and reset network  settings again . Can you test the Telus sim again does it still work ? But SOS indicates account /sim set up issues so I would send ticket right away because if time it takes to get reply if you figure out before support gets  back to you  great . But if sounds like you will need them anyways so with out delay I would reach out to be safe
fixin1
