Phone Call Connection Issues and LTE Issues
ericjonezy
Hello,  I've been with Public Mobile for a while now and I still have a specific frustrating issue and I've recently noticed another one.
On every call I RECEIVE, not outgoing, only receiving, there is typically a 5-20 second delay before I can hear or the other person can here me from the time I answer the call.  I don't know if this is in my head or what, but I've noticed the other person's carrier matters.  PM to PM it's minimal, 5s max.  Telus to PM, usually 5-10s. Roger to PM solid 15-20s pretty much every time.  I have posted previously about this issue, was re-issued an eSim and was told to factory reset my phone because it's probably a software thing.  It wasn't - this was about a year or two ago now I've just been dealing with it.
Recently, I started taking a different route home from work.  I've noticed that as soon as my phone no longer shows 5G all of my calls and data drop.  I can typically still text, I can send and recent messages via WhatsApp and Signal, but zero call will happen.  I can't load webpages, but like I said RCS, WhatsApp, Signal messages still go through.  Calls sometimes connect but I can't hear them and they can't hear me.  It's as soon as my phone shows "LTE" I could have anywhere from 2-5 bars of LTE or LTE+ and no webpage will load, and no phone calls will work.
I tried searching the forums and couldn't find anything about either of these issues - so if it is redundant my apologies but could I please get some help with these issues?
10 REPLIES 10
I have to ask if it already hasn't been...   have you tried a different phone? Granted, the eSIM is free but you need 15 days in between downloading one free or it's $5.
Have to be honest, and of course, because I don't live in your area, I'm wondering if it is indeed a phone issue? I dunno. Not much can be tested over a forum. Hahaha. OK. Back to the football game. Good luck brother.
ericjonezy
@slusagm  will do.  Thank you!
@ericjonezy ask PM to reprovision the account
Simply open ticket with PM using Expert Messaging. Click the Orange Chatbot icon on the lower right to start, or use this link https://expert-messaging.publicmobile.ca/guest/chat/
 (Use your Community account to login. For 2FA, you might need to use email to receive if you cannot receive the text on the phone.)
PM will reply you via Expert Messaging between 9AM-10PM EST (Mon-Sun)
(for help with Expert Messaging, check here: https://publicmobile.ca/en/get-help/articles/expert-messaging )
ericjonezy
@hairbag1  Hamilton Greater Area.  So there are spots that I know I'm going to be switching to LTE because the "signal is poorer" but I still have minimum 2 bars, typically 4/5 bars of LTE service, I just lose 5G.  As soon as I lose 5G I'm done. I could be right in the city of Hamilton, or Burlington, Niagara Falls and if it doesn't say 5G I'm not getting my calls through and my internet isn't working.
ericjonezy
@Chalupa_Batman Thanks for your response.  I've tried the airplane mode trick - my phone actually is in airplane mode daily as well as I work in tech support so forcing everything via WiFi for device reconnections is a daily occurrence.
This isn't an intermittent issue - I've been doing this for months now and it's every day when it toggles to LTE for the dropped calls/internet and as well as every phone call regards of my service coverage. I am just slow asking for tech support and things and it ALWAYS happens when I'm on the road with no internet so I forget 😝
@ericjonezy
so it's not a VoLTE issue. What general area in Canada do you use your cell ? Could be you're in an area that has fringe service. If you go to a different city or somewhere other than your local area, are symptoms still flakey ?
Chalupa_Batman
First, I would like to say thanks for searching the community first to find an answer instead of just posting. A lot of folks don't do that and often create redundant posts. You didn't. So I commend you for that.
One thing I recommend often that most providers suggest is airplane mode. Putting it into airplane mode for 5 minutes and shutting off the phone for 5 minutes and then turning it back on and turning off airplane mode. This reconnects your phone to the network/service.
Another thing you can check is if there are any service issues in your area.
https://www.telus.com/en/mb/outages
I do know there were issues last week with the Telus network which caused issues with PM. Oddly, here in Manitoba I never encountered any issues. Both on my Telus or PM.
EDIT: Sorry, one more thing to add. A Telus tech support chap told me to take it out of 5G and use LTE only to see if the issues go away or if it's a temporary solution while perhaps there may be issues with 5G at the moment. I do find LTE more reliable in Winnipeg. But that's just me.
ericjonezy
@slusagm  I've rebooted and reset the network settings, I've factory reset.  I have an eSIM.
@hairbag1
I couldn't find any settings for VoLTE on my phone - I checked in the SIM settings section and the best I have is selecting preferred 5G/LTE/3G. I went to that page, and ran the IMEI;
(Green Check) VoLTE Network
(Green Check) 5G Speed
(Green Check) eSIM
Manufacturer Google
Model Pixel9ProXLGZC4K
hairbag1
@ericjonezy
might be a a VoLTE issue. Here's some reading about VoLTE with a device checker at the end of the article..
https://www.publicmobile.ca/en/get-help/articles/volte
slusagm
What phone is that?
Did you try Reboot phone and Reset Network Settings?
Or did you try the sim card on another phone if you have a physical sim?
