e sim and new phone #
jesse39
Hi guys
I have a physical sim with an existing phone number. I want to keep that existing phone # with sim.
I just bought an e-sim and need a new phone # corresponding with the new e-sim. How do I proceed?
jesse39
Thank  you. I will create a new account.
Sansan
You cannot have more than one phone number on a account. You would have to create a new account.
jesse39
Yes, correct.
Yes, physical sim and e-sim on same phone.
Ok thank you for your help.
@jesse39
so, the old number with the old sim card and a new number with the esim?
you will need to setup another account with another email for that esim.  Are you going to put both on the same phone? doable but you need to make sure you set it up correctly
Whichever phone you going to setup the esim, download PM app, use the other email address to create a new account and subscribe a new plan
