10-07-2023
08:21 AM
10-07-2023
03:58 PM
computergeek541
Hello People,
I was wondering if some one can tell me the process of converting my own, a working public mobile physical sim card to an e-Sim card in iPhone and android too!
your response will be much appreciated
10-07-2023 11:03 AM
If your phone is eSIM compatible. I would recommend you stay with the SIM in your phone and use the eSIM while you are travelling outside of Canada and USA…like India.😉
10-07-2023 10:31 AM
HI @KD725
make sure you know that unlike physical sim, you cannot transfer your eSIM to other phone without paying another eSIM for $5. So, physical sim is cheaper and easier in the long run if your phone supports.
10-07-2023 09:37 AM
Here is some information:
https://www.publicmobile.ca/en/ab/get-help/articles/esim-faqs
Need to download Public mobile app to your phone that you want to install the eSIM.
10-07-2023 09:08 AM - edited 10-07-2023 09:12 AM
@KD725 wrote:Hello People,
@KD725 , here’s how I did it on my iPhone 14 Pro
For Existing Customers:
(I had my data on plus my Wi-Fi was turned on & connected to my home internet to be sure I had all connections while doing this)
I received an email notifying me that my SIM Card changed.
‘I can not stress this enough… please be patient when installing the eSIM’.
