11-30-2025 09:24 AM
Hi, my data is not working after a port-in from Rogers. Everything else is working and I alredy reste all network setting , swith my sim physical card and reboot my phone and verify and reste APN setting. The carrier is the latest version. I don’t know what to do now? How I can help from the support team?
12-08-2025 08:19 AM
Yes and finally it was the VPN that was not working well with the 5G and I add to remove it to make my data work. Thank you for your help
11-30-2025 02:13 PM
I did it and it’s still not working and I’m not able to reply to the CS AGENT. There is no reply button under his response
11-30-2025 02:08 PM
Not wotking
11-30-2025 11:36 AM
Please use this link to the Public Mobile Chat Bot which will direct you to creating a trackable ticket.
11-30-2025 10:09 AM
@Vany12 what phone do you have?
If you have an iPhone, update Carrier Profile
If you have an Android, check and update APN :
APN: sp.mb.com
Proxy:
Port:
Username: <blank>
Password: <blank>
Server:
MMS Proxy: mmscproxy.mobility.ca
MMS Port: 8799
MCC: 302
MNC: 220
Authentication Type: Not Set
APN Type: default,supl,mms
or default,mms,agps,supl,fota,hipri
(might need to include DUN for hotspot, please note case sensitive)
APN protocol: IPv4
APN roaming protocol: IPv4
or Turn APN on/off APN turned on
Bearer: Unspecified
MVNO (Mobile virtual network operator) type: GID
MVNO (Mobile virtual network operator)value: 4D (or try: 4D4F)
