11-18-2019 08:00 PM - edited 01-05-2022 09:46 AM
Hi,
I got duplicate charge every month now, sept , Oct. and now Nov, i tried to follow instruction to open a ticket, but seems your website has problem. pls give me instruction. thank you !
11-18-2019 11:28 PM - edited 11-18-2019 11:30 PM
@S0phie wrote:Hi,
You can try Simon again later. It might be a temp website issue.
11-18-2019 10:48 PM
@S0phie wrote:Hi,
Hi, where are you seeing the duplicate charges?
Do you see them on Payment History section when you logon your self-serve account?
If not, is it possible your credit card is being used by more than one PM account?
11-18-2019 09:53 PM
11-18-2019 08:42 PM
If you are having problem with the ticketing process, you can directly private message a moderator (supposedly takes a bit more time since moderator needs to confirm your identity)
Send a private message to moderator through the following link :
11-18-2019 08:08 PM
Please click on the question mark icon on the bottom right of the screen to contact a moderator regarding this. Only a moderator can check and make sure you do not get duplicate charges again.
Do check your available funds in self-serve. If the funds are there, then I would suggest that you leave it there for future charges instead of asking for a refund as that process may take longer.
