08-18-2023 01:46 PM
I upgraded to 15gb plan but realize I do not need that much data. Am I able to return to my previous plan including the promo deal I had at the time?
08-18-2023 06:07 PM
Hey @MCRAPPER everyone here has already given their answer and are correct.
Sadly there is no account, which there REALLY should be, between $25 1GB to $39 20GB.
You will just have to keep checking back every 30 days for promos.
08-18-2023 03:21 PM - edited 08-18-2023 03:22 PM
Your old promos will be gone. Existing add-on's such as holiday bonuses will remain on your account. If your have legacy rewards (money off every month for loyalty, auto pay, friend referrals), those will stay. As for the core plan you previously had, you can only go back to it if it's still available as a current offer today.
08-18-2023 02:04 PM
Change plan in 3 easy clicks
Once you find plan you want be sure to (change on renewal )So you don’t lose money on current cycle
08-18-2023 01:51 PM
Hi @MCRAPPER
you can change plan using Change on Renewal, but you can only change to plan currently available. So, if you had a retired plan with promo, likely No, you cannot go back 😞 But pick one on the list now that is cheaper
