11-20-2023 11:05 AM
11-20-2023 12:43 PM - edited 11-20-2023 12:44 PM
Your Autopay discount will be reduced to $1.70.
11-20-2023 11:25 AM
HI @dorisyeewan
you are correct, your $2 Autopay discount and $5 loyalty will stay with you. Changing plan won't affect rewards. Just don't manually migrate to the new rewards system
11-20-2023 11:22 AM
so that'll make the new plan $34 - $2 - $5 = $27! thats a great deal, thanks!
11-20-2023 11:10 AM
@dorisyeewan The rewards you mention are not tied to your plan, they remain constant regardless of which plan you switch to.
11-20-2023 11:07 AM
You will not lose any of your rewards when you switch.
