07-22-2022 10:14 PM
i am upgrading to a i phone se 2020 do i need to upgrade to a 4g plan or can i keep my 15 dollar plan?
Plans
07-22-2022 10:17 PM
Thank you that is a relief its a steep price increase for 4g on here
07-22-2022 10:16 PM - edited 07-22-2022 10:17 PM
@juanvaldez Yes, you can keep your $15 plan with your new iPhone 🙂
The difference with the new 4G plan is just faster speed for internet. It is not a requirement for new phone.
If you are happy with the speed you have now, there is no need to make the change
Again, keep in mind your $15 plan also allows you use the 4G network (LTE) , just at a slower speed
Tell you the true, faster the speed, faster to use up the data. You only have 250Mb included in your $15 plan. So, if you are happy with what you have now, stay with the $15 plan and leave the browsing on Wifi 🙂
